Issue number two..
Having the car sat for a few days, it drops to the bump stops. Now I've read that quite a few fullfat owners have this issue now, but mine has a twist:
It won't raise up again for quite a while.
I've pulled live values from the suspension menu in the GAP-tool, and it shows normal (I guess?) pressure values in the reservoir, compressor temperature indicates that's not running, but even while driving for 10 kms it stays reaaaaally low.
Then, all of a sudden I can see reservoir and corner valves open, reservoir pressure dropping, compressor coming on (I'm guessing from airflow to the suspension bags) and the height sensors showing the car raise back to normal.
As mentioned, I already know I have a bad compressor, but that shouldn't prevent the valves from opening (either from not getting the signal, or just plain old stuck).
| Click image to enlarge |
