Home > Technical (L322) > Noises and getting to know one another...
Ragnorak
Another day and another noise I haven't noticed. This noise is coming from the battery compartment area.
https://youtube.com/shorts/CWOtgdUFP2U?feature=share
Initially I thought the fuel burning heater but when turned on by the timer it makes no real sound. Is this normal or do I need a new ECU fan or something?
Post #655320 1st Feb 2023 7:23am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Welcome ! If you check out the first few pages of this thread you’ll notice that’s there’s an ECU in front of the battery with a fan attached; that may be the culprit. It’s normal for a fan to run in that area and to continue for a while after the engines been switched off but yous does sound noisy. Perhaps something caught in the fan?
https://www.fullfatrr.com/forum/topic43662.html TDV8 4.4 2012
Post #655408 1st Feb 2023 8:47pm
Ragnorak
Thanks for the response. I have seen the fan but it's not spinning, not sure what conditions it spins under to be sure it's not working. It spins freely and there is no sign of resistance in it so unknown if this is the culprit...
Post #655409 1st Feb 2023 8:51pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
FBH. This sound cannot be confused with anything else.
Post #655440 2nd Feb 2023 5:33pm
Ragnorak
Thanks for having a look. If this is so then is this noise incorrect or is this how it should sound?
Post #655452 2nd Feb 2023 8:11pm
