Home > Technical (L460) > L460 Temperature Gauge
nrgltd
In the manual there’s a reference to a temperature gauge. Anyone found it yet??
Post #655433 2nd Feb 2023 4:46pm
CS
If you configure your instrument panel to 'Dial' it should be at the bottom of the right hand dial. Only Range Rovers since 1988
Post #655434 2nd Feb 2023 5:05pm
nrgltd
Apologies. I mean engine temperature.
Post #655437 2nd Feb 2023 5:39pm
CS
That is the engine temperature indicator, i.e. the arc with blue for cold on the left and red for hot on the right. See for example the 'Instrument Panel' page on ownerinfo.landrover.com for L460 2023 which shows it. Only Range Rovers since 1988
Post #655442 2nd Feb 2023 7:16pm
nrgltd
Thanks. I can see that but mine’s a PHEV and the right hand panel shows the battery charge. I think the temp gauge is only for ICE versions.
Post #655464 2nd Feb 2023 9:57pm
