Home > Technical (L322) > Advise on suspension |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1157 |
Besides the obvious checks for leaks, if this is the maximum pressure you are obtaining then if you have no leaks and the pressure sensor is reading correctly, then your compressor may need an overhaul. AFAIK the cylinder pressure should be up to 180, not 154, which would also explain the slower operation when the car returns to normal height. As you probably know, O/H kits are quite cheap. |
26th Jan 2023 10:43pm |
andyfid Member Since: 10 Apr 2016 Location: barnsley Posts: 101 |
I am going to give a overhaul and I will have to order a dryer kit aswell might aswell do that while itโs off hopefully it will be better when itโs all being done thanks for the heads up ๐ |
26th Jan 2023 11:20pm |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 679 |
Have you tried removing the brass sintered filter on the pump inlet ?
27th Jan 2023 3:20pm |
I will give it a try when I put the new piston ring in think I have a spare one in the tool box |
27th Jan 2023 9:28pm |
Changed the orings on all main valves and cross overs and also did the ring in the compressor and clean out the brass filters and good news is the pressure is up to 184 psi and takes about 1min20seconds to get to ride hight ๐ |
31st Jan 2023 7:44pm |
