Lower glove box not opening | |
I'm getting layers of electrical issues. I haven't been able to tow because the never-fitted hitch had jammed its own lock mechanism. Now that's been resolved and securely fitted, I still can't tow because the trailer lights don't work, At all. I've checked fuses in the boot, now I need to check fuses that are behind the lower glove box... and that stopped working last Monday.
The upper box is opening as normal, no joy with the lower. Being a facelift 2009 MY with a digital dash, the normal L322 wiring diagram isn't right. Is there a fuse (ideally not behind the lower glove box) that feeds this switch? How do I get the switch out to check for voltage and maybe even false-feed the lower circuit to get it to open? Mike A
2009 L322 Vogue (facelift)
1990 110 V8 GS EOD (since 2002)
1980 109 SIII RAF Crash Rescue Ambulance (since 1995)
(and fifteen other SIIIs, 90s, 110s, V6 Freelander, D1s, D2s, D3s owned and sold since 1987)
