Home > For Sale & Wanted > [SOLD] 2006 Supercharged Range Rover
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Now sold
2006 Supercharged Range Rover - £3,500 ono
232k miles
MOT due November 2023
Buckingham blue, black leather interior
5 previous owners (I am the 6th owner)
It has the usual Supercharged high specification as well as a Westfalia detachable towbar and a 10% reduced supercharger pulley.
I have owned this car for almost 8 years. It presents very well and externally and internally doesnt look like a car of this age or one that has covered this mileage. It passed the MOT inspection earlier this week with only one advisory - which was the tester noting the underside is under sealed!
Today it has had an oil service. During my ownership I have carried out alot of preventative maintenance, if the car has needed something it has recieved it - e.g. its had the supercharged rebuilt, all engine ancilaries and belts replaced, all cooland hoses, brake lines renewed, radiators, viscous fan, the list is long.
A refurbished gearbox was installed by the last owner, it wasn't quite right so I had the valve block tested and solenoids replaced and then the gearbox firmware updated. It works perfectly.
The rear sills / arches have recieved rust repair and this was done properly with corrosion cut out and repair panels or rust free cuts welded in, i.e. It wasn't bodged and is something the new owner will not need to worry about.
Tyres are Goodyear all round with only a few thousand miles on. Brake discs and pads are recently replaced and have only covered a few thousand miles.
Bad points:
- there are some gaps in previous service history with nothing recorded between 50k and 117k miles
- where the rear quarter panels have been painted following the arch repairs they don't have the same level of shine as the rest of the bodywork. They are presentable but to may warrant a repaint if you are minded to.
- over the last year it has been intermittently throwing an engine warning for both banks running lean. This is most likely a vacuum leak or air leak somewhere rather than a sensor or an actual running issue, because it affects both banks at one. I have fitted a new PCV, oil cap and o rings to front breather pipe as well as finding an re-attaching a loose vacumn pipe at the rear of the supercharger. This may well have addressed the issue but as it is an intermittant warning light only time will tell. Therefore any buyer must accept this (and that it's an old Range Rover that will try it's best to let you down!)
- the paint on alloy wheels are showing signs of age and to be perfect would benefit from refurbishmemt
Overall a great vehicle and I doubt you will find one as good as this for the money. It is priced to reflect the high mileage.
My personalised plate has been removed and the registration is now FN06 XLD
Located in Evesham, Worcestershire
Post #647442 5th Nov 2022 7:16pm
dhallworth
That’s a clean looking car that doesn’t look like it’s done anywhere near that mileage, especially the edge of the drivers seat!
Hopefully it sells quickly!
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #647525 6th Nov 2022 6:45pm
kezbo1981
I should add, with this being a 2006 it is in the lower cost road tax category - something like £360 per year vs £600. Also ULEZ compliant.
Post #647791 9th Nov 2022 9:04pm
joncorry
United Kingdom 2002 Range Rover HSE 4.4 V8 Tangiers Orange
That is really nice! I’m sure it wont hang around. 2002 L322 4.4V8 - G4 Challenge Car - Australia leg
2003 Defender G4 110
2008 Discovery 3 G4
1968 Series 2a
Post #647824 10th Nov 2022 11:56am
kezbo1981
Price now reduced
Post #649088 25th Nov 2022 10:44am
benb91
Still for sale?
Post #650950 16th Dec 2022 10:43pm
kezbo1981
Yes still for sale - which has done me a favour in the last week, it's great in the snow!
Post #650957 17th Dec 2022 7:32am
24valve
United Kingdom 2010 Range Rover Autobiography Black TDV8 Santorini Black
I'll be giving you a call if my 03' sells! 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #651099 19th Dec 2022 9:55am
Skipper
Any sign of your warning lights since your first post?
Post #653038 8th Jan 2023 10:22pm
kezbo1981
Yes unfortunately it came back on (with lean running on bank 2 only this time) which is why I haven't really been pushing the sale. However! Over Christmas I bought a smoke machine and have smoke tested the inlet system which revealed an air leak around the brake servo vacumn line. I bought a new seal / coupling for that which I fitted yesterday, that leak would definitely have resulted in an engine warning light as unmetered air would have been entering the engine. I am hoping therefore that this issue is fixed, but need to drive it for a good few miles to be 100% certain.
Post #653041 8th Jan 2023 10:52pm
Floopy
Hello Kezbo,
Is this still available? I'm new to the group so can't PM you yet.
If it's still available please could you send me a message?
Many thanks
Mat
Post #655052 29th Jan 2023 12:51pm
kezbo1981
PM sent
Post #655054 29th Jan 2023 1:10pm
Floopy
Thanks - just checking now 2006 L322 Vogue SE 4.2
Post #655057 29th Jan 2023 1:19pm
Drellis
Hi, has the eml been solved?
Thanks
David
Post #655077 29th Jan 2023 6:22pm
kezbo1981
It's currently on sea trails! The joy of fault finding an intermittent fault code...
Post #655078 29th Jan 2023 6:24pm
