Home > Maintenance & Mods (L405) > 4.4 SDV8 Crank Pulley |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
What is wobbling? The centre rubber bit or the outer edge of the pulley?
27th Jan 2023 10:48pm |
Bigfella70 Member Since: 22 Jan 2016 Location: Yorkshire Posts: 104 |
Thanks for that, done some further research and it turns out the pulley is all metal construction, so a bit of a puzzler as to why it seems to be “wobbling”.
28th Jan 2023 7:55am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
It won't be solid as it includes a harmonic balancer. There will be a thin rubber layer to allow the outer section to move a little. |
28th Jan 2023 9:37am |
That’s interesting, thanks. So likely that the pulley is a two piece assembly with a thin rubberised element between the pieces. Current
28th Jan 2023 3:43pm |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
It is. Zoom in to the pic above and just to the outside of the section with the balancing holes drilled you can see the rubber mass-isolating ring. |
28th Jan 2023 3:48pm |
snickering hound Member Since: 08 Oct 2016 Location: Northamptonshire Posts: 5 |
My wife’s Q5 3.0 TDI has a harmonic balanced crank pulley and it failed around 12 months ago and fell off, fortunately on the driveway so it just fell on to the undertray. Pig to get at the bolts to replace it but possible. If yours is showing signs of wear it’s surely a good plan to replace it before it inevitably lets you down. Late 2015 L405 Autobiography 4.4 in Loire blue with silver roof |
28th Jan 2023 9:45pm |
Fully agree with that! Actually booked in for the pulley changing this coming week.
29th Jan 2023 9:01am |
