Home > In Car Electronics (L322) > LRover vogue se 58 plate flashing power button to infotai
DaveAbbott
Guys
I am new to this so would appreciate some guidance. My infotainment sytem has been working fine, and then today it keep cutting out and rebooting itself , all works for a minute or so and then crashes again.
The red light on the power button is flashing, and I cannot turn it off . Its like a power cut off and then restarts.
Can anyone point me in the right direction as to what to look for please
regards
Dave A
Post #654923 27th Jan 2023 7:51pm
dhallworth
When it starts to reboot do you have a Land Rover logo on the screen?
It's usually a module on the MOST system that causes this and more often then not it's the bluetooth module that gets water in it and fails.
You can buy a MOST loop adapter on Amazon so that you can bypass it to rule it out as a fault.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #654938 28th Jan 2023 1:10am
DaveAbbott
Thank you David I will try that.
Post #654944 28th Jan 2023 8:03am
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
You can make your own MOST loop adapter.
Cut a BIC Crystal Pen to a approx. 3cm short piece and stick the two endpieces oft the most wire in the way that the two ends touch together and secure with a tape.
https://en.wikipedia.org/wiki/Bic_Cristal
Post #654956 28th Jan 2023 11:26am
DaveAbbott
Have tried connecting the optic cable as described
Gys
Follwed the advice of connecting the fibre optic cables without any joy, in fact where I was getting intermittent radio/sat nav ertc now I am locked onto the Range Rover Screen, but even that cuts out and then returns a few moments later.
I now have no other functionality whatsoever.
Where might I find fuses for this/ is there a relay somewhere
Have yet to acquire any form of Workshop manual so would also appreciate advice as to where to access that
Best regards
Dave
Post #655046 29th Jan 2023 11:27am
DaveAbbott
Ive had tried bypassing the Blue tooth module as suggested
Guys
Appreciate you help so far, I have tried by passing the Bluetooth module without success
The screen fires up and the Nav, Radio and computer screens all show,( I ve not tried CD or TV )
BUT after 30 secopnds or so the screen goes blank and then some short time aftert immediately re boots
and we go round in circles.
If I leave it on radio, I get about 30 seconds worth of broadcast and then it cuts out, only to reboot itself a few moments later.
Can anyone suggest what I need to look at now
Kind regards
Dave
Post #655153 30th Jan 2023 3:48pm
DaveAbbott
Infotainment keeps cutting out
My screen keeps cutting out and then rebooting.
Have tried the MOST diagnosis adn on advice have now tried changing the amp - to no effect.
What do I do now?
Any suggestions as to who I should speak to , or where to get professional advice/ diagnosis
When powered up all works , but then it all cuts out and reboot a minute or so later
Help please
Dave
Post #658436 4th Mar 2023 12:36pm
