Supply Mode is exactly that, the MXS-7 will act as a constant power supply providing 13.6V and up to 5A.
it’s similar to the “Float” (final) phase in the normal charging cycle, except it will not turn off & on as required, it stays on permanently, the idea being that you use it to prevent the battery draining from a constant drain, say you were using a 12V polisher or other 12V tool from one of the car 12V sockets.
Did the battery get hot or gas in this time? The MXS-7 should not cause damage to the battery used in this way, the battery should not demand current from the CTEK unless there is demand from the vehicle, either by equipment (or parasitic drain).
I can only suggest the battery was already on its way out, and you may not have noticed if habitually leaving the CTEK connected to the vehicle, it would mask the weak battery. Other more experienced forum users may offer further insight for you hopefully. V6 Vogue - “Less is More” - less to go wrong!
