Home > Technical (L322) > Intermittent transmission fault / fail to start - 2006 4.4 |
greenrover Member Since: 02 Jan 2023 Location: Idaho Posts: 12 |
Currently ripping apart the center console to get to the ignition switch... surely these splices are not factory? There doesn't appear to be anything aftermarket in the car so I'm very confused why these would be here. Perhaps I'll find out once I get it more open.
19th Jan 2023 1:13am |
Seems to be the transmission electrical connector is the issue. I replaced the sleeve that goes into it per the atlantic british instructions during the transmission service, and somehow it did not go in right, even though everything locked together.
23rd Jan 2023 8:11pm |
Billie Member Since: 12 Oct 2020 Location: south-west Posts: 49 |
We had most of those codes come up on the GAP. Took it over to Bristol Gearbox, they carried out an electrical test (passed) and now they are saying a strip down of the mechatronic unit and needs a full transmission overhaul. £2650 + vat + anything else they find. We are wondering if it’s worth doing, over 200000 on the clock. Thing is we have spent a fortune the last year, new PIR tyres, brakes, discs, full service with all filters, gearbox pan change with service…..the list goes on and on |
24th Jan 2023 2:11pm |
That sucks... I wonder if you could do the teardown yourself and just bring in the unit to the shop so they can do whatever computer wizardry they need to, then finish up the service yourself. Getting the unit out and replacing solenoids isn't hard at all.
24th Jan 2023 2:18pm |
We wish we could, arthritis stops a lot of things. We can only check things, any repairs, it goes to the garage.
25th Jan 2023 8:10am |
If it's been a good car and this is the only issue, I would spring for the tranny rebuild. If you junk it you'll have to buy something else, and that's going to cost even more, and could come with issues of its own. 2006 HSE 4.4 gasser |
25th Jan 2023 4:14pm |
