Home > Maintenance & Mods (L322) > Heater Matrix to rear pipe (8K520) question
24valve
United Kingdom 2010 Range Rover Autobiography Black TDV8 Santorini Black
Hi,
My (new to me) 4.4tdv8 autobiography black has pipes that go from the heater matrix above the gearbox to the rear heating. I dont know if all l322's of this era have them, but after chasing a coolant leak, I've found the top of one of these aluminium hoses has a pinhole leak in it. I know its coolant and after presurising the system and seeing it p!ssing out above the gearbox and the sound deadening becoming waterlogged, I ventured underneath, took the sheilds off and got a nice antifreeze cocktail.
anyway, I've identified the part on microcat (8K520) in the diagram, but I cant seem to find a supplier. Does anyone know anywhere I can get hold of one? - or is it best to phone the dealer.
Also has anyone changed one before, or if a replacement pipe is hard to get, is there anything that would repair an aluminium pipe?
Cheers
Neil.
 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #654493 23rd Jan 2023 5:14pm
Gsxr1250dave
You could repair it with chemical metal I'm sure.
Post #654499 23rd Jan 2023 6:03pm
rjff
I believe the price for the part if available is in the "you'd better be sitting down" territory.
Recall a thread somwhere that had the owner replacing the corroded sections with good quality rubber/suitable pressure hose.
Hope my memory is still correct. Cheers
Richard
Gap IIDBT
Post #654509 23rd Jan 2023 7:46pm
24valve
Would Chemical metal be able to handle the hot and cold/water pressure and all that? 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #654511 23rd Jan 2023 7:48pm
Gsxr1250dave
Look up the specs and decide for your self, if in doubt seek from a breakers as the new pipe it expensive or as mentioned replace with hose.
Post #654516 23rd Jan 2023 8:05pm
24valve
hmm. I think the part number is actually PFV500270 - which is about 135 quid plus the dreaded. Not as bad as I thought tbh. It looks like a bit of a pig of a job to do, so I'd rather only do it once! 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #654518 23rd Jan 2023 8:06pm
