Home > Maintenance & Mods (L405) > Rear Camera: Stopped working, dried out, TSB upgrade
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
My rear camera failed last night after snow/sleet/rain all day.
The GAP IIDTOOL showed a fault.
I cleared the fault several times and the picture came back, but green.
I removed the camera and took it apart. There was no water inside the camera body, but instead only in the lens.
I put the lens body in a Tupperware container and set my wife’s hair dryer to blow warm hot air on it for an hour.
Then I completed the TSB upgrade I found on an Evoque forum. The TSB drills two holes in the camera bracket to allow water to drain from the housing rather than submerge the camera and letting moisture deep into the lens. Apparently, 2016+ vehicles have two holes from the factory. These two pictures are from an Evoque and opposite the FFRR.
I didn’t get it all done until after dark, but the results speak for themselves. Crisp and clear in the red glow of the rear lights.
Saved $300-$600 CAD 🥰 Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #654426 23rd Jan 2023 2:40am
knwatkins
Brilliant! Thank you for sharing this Bora. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #654517 23rd Jan 2023 8:05pm
