Home > Technical (L405) > FBH working but no heat |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1694 |
Morning folks
22nd Jan 2023 1:45pm |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 773 |
The FBH will shut down if the battery is low. MY23 D350 HSE
22nd Jan 2023 2:23pm |
Thx Phil
22nd Jan 2023 2:50pm |
Thx Phoenix
22nd Jan 2023 3:33pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
It would depend upon how warm the ambient temperature sensor thinks it is. If the FBH failed to fire, (IIRC) it would retry twice then shutdown with a hard DTC and locked out, the combustion fan certainly wouldn't continue for over 15 mins after that.
22nd Jan 2023 5:34pm |
Thx
22nd Jan 2023 6:49pm |
Also check the actual values of the temperature sensors - might give a clue, or at least confirm they are reading accurately. |
22nd Jan 2023 6:53pm |
Right - not sure if this is going to be of any use but IID reported the following
23rd Jan 2023 6:04pm |
Well if the water pump isn't running, that would explain it - I'm fairly sure the FBH would/should fail to start if there is a detectable fault with it's circulation pump.
23rd Jan 2023 7:04pm |
