Home > Technical (L405) > 2013 RR L405 Autobiography with Odd Issues
KarlC
United States 2006 Range Rover HSE 4.4 V8 Zermatt Silver
Cam-Tech-Craig wrote:
I assume the battery wiring is nice and snug? (Tight for us brits 😏)
Yes it is.
Thx Thumbs Up
Post #640859 25th Aug 2022 3:41pm
It would involve taking the seat out, then inspecting both the wiring loom that goes to the seat and the buried wiring loom under the carpet! This loom has a habit of rubbing/chaffing on the body and causing spurious faults around the can bus system…
You would really need an electrical expert to diagnose these types of issues I’m afraid…
Good luck sir 👍🙏👍
Post #640885 25th Aug 2022 7:19pm
KarlC
Good luck sir 👍🙏👍
Big thanks for your reply, Im not sure if this was an issue.
Thx Karl
Post #640890 25th Aug 2022 7:59pm
harryboy
Hi there, just wanted to ask if you got to the bottom of this and found a solution?
Many thanks,
Harry.
Post #654320 21st Jan 2023 11:51pm
harryboy
Bump, I’m having the exact same issues as this and can’t find a solution.
It’s intermittent and I loose all medium speed CAN.
Have changed small and large battery and am thinking of changing alternator next.
I’ve removed the seat and checked wiring under seat and behind drivers door card and all appears ok.
Post #654771 26th Jan 2023 1:28pm
