Home > Technical (L322) > “Critical Engine system” anyone had this?
Warkman
2012 4.4 v8 Deisel
Started this morning and got the red triangle with the words “critical engine systems”
Has anyone had this?
Post #654149 20th Jan 2023 3:06pm
Warkman
Well, I connected to GAP iid and these were the only four engine errors showing:
[/img]
Post #654159 20th Jan 2023 4:48pm
Kot
Can you clear them (DTC) and see what returns as some of these have activated at a different mileage, the last being throttle peddle position, which must be the culprit 2018 SE SDV8 4.4 Byron Blue
Post #654171 20th Jan 2023 6:06pm
garyRR
Usual cause of this error is:
A) dirty MAP sensor. When was it last cleaned?
B) failed o-ring inside the plastic pipe connection on the throttle body - check for oily soot in the vicinity. Diagnostic / temporary fix is to use gas spec PTFE tape or silicone tape wrapped around the throttle body union
C) A split donut hose or top intercooler hose. Check for splits in the small 4 hoses on the donut and the 2 large ones near the front of the engine bay
Once all are covered, try a steady motorway cruise for 20 miles and if it still hasn't cleared / returns, force a DPF regen with the IID tool. 2015 Range Rover Autobiography 4.4 SDV8
Post #654178 20th Jan 2023 6:41pm
Warkman
Yes, noticed tgat so I’m doing that tomorrow now I have the GAP change car code
Post #654180 20th Jan 2023 7:07pm
