Home > Technical (L322) > Need help with Air Suspension Inactive |
tilemanvogue Member Since: 22 May 2011 Location: Aylesbury Posts: 24 |
I live in Aylesbury and was hoping someone near might be able to help. I need a mobile mechanic to re-activate my Range Rover. I had fitted new Air Suspension Strut and now I need code reset. Discovery 3.9
23rd May 2011 12:32pm |
You should fine the EAS will pump itself back up, at least to standard height? Then you can drive to your dealer or indy...
23rd May 2011 2:51pm |
Thanks for your replies
23rd May 2011 3:56pm |
I have heard that if you disconnect battery leads and then touch them together that this resets computers etc, is this true, and do you think this might help. On my P38 changed all air suspension, after a leaking bag, fitted new and it all fired up ok, no restting. Discovery 3.9
23rd May 2011 3:59pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
dont touch the leads together ...let the range rest for 20 minutes before dis-connecting the battery..if you are in swindon i can try out my RAC and see if i could clear your faults.. |
23rd May 2011 4:24pm |
Hi Stan Many thanks for your kind offer and help, not near Swindon at least not for a while Discovery 3.9 Range Rover 4.6 HSE 1998 L322 Range Rover Vogue 4.4 2004 Last edited by tilemanvogue on 23rd May 2011 5:05pm. Edited 1 time in total |
23rd May 2011 4:52pm |
herman maire Member Since: 28 Nov 2010 Location: up north Posts: 51 |
I would just disconnect the battery leads and let it sit over night......
23rd May 2011 5:00pm |
Thank you for that I will give it a try, luck I need lots of it Discovery 3.9 Range Rover 4.6 HSE 1998 L322 Range Rover Vogue 4.4 2004 |
23rd May 2011 5:04pm |
Agreed - if it's sat on the bump stops then one of the sensors could have gone "out of range" In theory the plausibility checks should still allow for standard height to be achieved. Is it up at all, or is it on the bumps? |
23rd May 2011 5:06pm |
The others are all hard and up to normal height Discovery 3.9
23rd May 2011 5:09pm |
One thing you want to be sure of and I made this mistake a few months ago when I replaced both my front struts.
23rd May 2011 5:23pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
i had this after fitting my front airbag and it turned out i didnt need it reset but that there was a pipe from under the bonnet that had some how come disconected due to the air bag leaking so try that "RANGEISM WILL NOT BE TOLERATED"
23rd May 2011 5:24pm |
Discovery 3.9 Range Rover 4.6 HSE 1998 L322 Range Rover Vogue 4.4 2004 Last edited by tilemanvogue on 23rd May 2011 5:43pm. Edited 1 time in total |
23rd May 2011 5:38pm |
Sorry but the pipe from what do you remember, but I will certainly take a good look, thanks Discovery 3.9 Range Rover 4.6 HSE 1998 L322 Range Rover Vogue 4.4 2004 |
23rd May 2011 5:39pm |
