Home > Technical (L322) > Manual Reset of *Service Required* - L322 2010 LCD
CADjockey
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Is there a manual way of resetting the *Service Required* message on a 2010 FFRR Vogue
with the digital cluster?
Had it serviced yesterday, not at a dealer as well you might imagine, but they forgot to reset.
Or is this only achievable with a plug in diagnostic unit these days?
Your help appreciated! 2010 FFRR VOGUE TDV8 Stornoway Grey - Current
2008 RRS HSE TDV6 Zermatt Silver - 163k - Gone...
Post #318759 20th Mar 2015 8:06am
i think it is ...an iidtool would reset it .. ... - .- -.
Post #318761 20th Mar 2015 8:09am
CADjockey
I was afraid of that. The lack of anything on YouTube or anywhere else I can search
seemed to indicate it being so...
I was just trying to avoid the need to return to get it reset as I know they have all the
kit being the LR specialists they are.
If anyone else knows different, let me know.
Thanks Stan. 2010 FFRR VOGUE TDV8 Stornoway Grey - Current
Post #318773 20th Mar 2015 8:40am
See below… Thumbs Up
Post #318777 20th Mar 2015 8:50am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
From one of the L322 (4.4 TDV8) groups on the book of faces this morning:
Facebook Group Member wrote:
Update on removing” service required “ on 2011 TDV8...... You don’t need an IID tool.
Open drivers door and bonnet, put ignition on, don’t start car, push both pedals to the floor for 1 minute, turn ignition off, close bonnet and door, start car.
Not sure if this is a wind-up or not, so anyone who doesn't have an IID tool might want to give it a try and report back. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #653992 19th Jan 2023 9:31am
Holy thread resurrection Batman! Laughing Whistle Bow down
Yes you are correct sir! It has come to my attention in the last 5 or 6yrs that there is a back door, into Range Rover service light reset…
So, bonnet up, drivers door open, ign on but don’t start engine! Then two feet hard down on the peddles and voila! You should get a message “service reset in progress” then 10 secs later “service reset complete”… I think I would do it twice to be sure…
Thumbs Up Good luck 🤞
Post #653996 19th Jan 2023 9:41am
DrRob
Worth a try and then check on the IID if oil dilution is reset to 0. That's the acid test I'd suggest.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #654024 19th Jan 2023 2:51pm
pcourtney
can confirm that works - what a back door Smile
Post #655417 1st Feb 2023 11:13pm
glenney
Yes the door and bonnet thing worked for me too
Post #691592 30th Apr 2024 9:32am
