Home > In Car Electronics (L405) > Odd key fob behaviour
Hi,
If anyone has seen this and got a fix I’d appreciate it.
One of my fobs will not work with keyless entry, but it will work on all the buttons to unlock etc. however it won’t start the car, car says to put the key near the steering column, but still doesn’t detect it.
I can get it to work if I press the unlock button and then try to start the car. It’s as if the key stops talking to the car unless it’s manually activated by pressing a button, but then stops soon after.
Car is under warranty but wanted to see if anyone else has this. I’ve also tried new batteries in the fob and get the same result.
Thanks Discovery 4 HSE
Post #652478 4th Jan 2023 7:19am
As an update.
The dodgy fob has drained 2 new batteries. It is booked in next week for the dealer to look into it. Discovery 4 HSE
Post #653877 18th Jan 2023 11:09am
Gremlin500
@RRUK:
Great, hope you get it sorted, don’t let the Dealer fob you off………. Rolling with laughter Rolling with laughter Rolling with laughter
Mr. Green sorry, I just couldn’t resist……. Embarassed Embarassed Embarassed “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #653901 18th Jan 2023 2:59pm
PeemLow
2019 Range Rover Vogue SE 5.0 SC V8 Fuji White
Just had a similar issue. Fault was diagnosed to a loose connection at the antenna located in the roof of the cabin. Headliner had to be dropped to get at it. Took dealer 3 days to find fault and repair. Completed under warranty.
Post #653981 19th Jan 2023 4:51am
Was your issue with both keys though? This only happens with one of them to mine Discovery 4 HSE
Post #654002 19th Jan 2023 10:45am
PeemLow
Issue started off with one key then quickly moved to both. Dealers first attempt was to reprogram the keys and that worked for about 20 mins. It was only first start up in the morning that neither key would be recognised by the car at all and had to be held against the steering column to start. Restarts after that in the same day mostly worked ok if the car had ran for 10-15 mins or more, then next morning back to holding it against the column. At no time during this behaviour though did the keyless lock/unlock ever work.
Post #654008 19th Jan 2023 11:16am
DiscoTruck
Sweden
Did it lock (pressing the dent in the handles) as it should but not unlock when you grabbed the door handles?
Could you open the trunk keyless and start?
Post #698077 14th Aug 2024 4:59pm
