Home > Technical (L322) > L322 Dipped Beam Failure
GUMBALLER
Hi. 2002 V8 petrol L322 fitted with 2006 headlights.
I had an intermittent offside dipped beam failure which is now a permanent failure.
I’ve changed the bulb, the ballast, the lights switch with no success.
Does anyone know which terminal to volt test on the 16 pin plug?
There doesn’t appear to be a fuse for the dipped beam either.
Any advice appreciated.
Thanks
PFA
Post #653741 16th Jan 2023 5:46pm
Here you go...
 Pete
Post #653786 17th Jan 2023 1:00pm
GUMBALLER
Many thanks
Post #653799 17th Jan 2023 2:44pm
GUMBALLER
Haylands wrote:
Here you go...
Many thanks
Post #653845 17th Jan 2023 11:24pm
GUMBALLER
So, after testing it appears I have no power on the dip beam wire.
I don’t know what to check now as there appears to be no fuse 🤷🏼
Any advice very much appreciated.
Post #654046 19th Jan 2023 7:47pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
On a 2002 it'll be BMW electronics. The BMW light control module or LCM maintains a series of counters for short circuits, bulb failures and so on. If the counters reach a certain threshold the LCM disables the power feed to the circuit or circuits affected. The counters can only be reset using diagnostics, which on a BMW would be done with Tool32 from the BMW Standard Tools.
I'd start there - I've never tried BMW diagnostics on a RR but I'd guess they may work against the BMW shared modules.
Post #654051 19th Jan 2023 8:23pm
GUMBALLER
Much appreciated Danb_220_2019
Post #654053 19th Jan 2023 8:32pm
GUMBALLER
Very much appreciated Thumbs Up
Post #654056 19th Jan 2023 8:46pm
Danb_220_2019
No worries!
Post #654057 19th Jan 2023 8:55pm
