Home > Maintenance & Mods (L322) > Apologies in advance for another KEY debacle question. |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
The blades can be swapped & yes you can programme it from your GAP ID tool.
16th Jan 2023 9:38am |
Weird Member Since: 14 Dec 2022 Location: Maine Posts: 16 |
Thanks, I forgot that we did verify that the whole blade/pivoting assembly would swap over to the new housing. Still very curious what I have going on with the functioning key. If its just a 433 mhz case with 315 mhz guts and blade? Am I to assume that the chip in the housing must be at the very least statically functional in order for the blade to start the Rover? 08 l322 4.4 HSE Black/Jet. |
16th Jan 2023 1:14pm |
It would appear that is the case. As far as i'm aware the 433mhz & fixed blade were pre 2007 vehicles only. You appear to have the correct type of key fob. No doubt someone else on here will confirm this.
16th Jan 2023 1:32pm |
Agreed, I have all the tentacles of my feelers out there right now utilizing a few forums and FB groups. Thanks. 08 l322 4.4 HSE Black/Jet. |
16th Jan 2023 1:47pm |
Update: I just called the dealer, gave the parts department the vin# and they confirmed my Rover transmits on 315mhz, so there is that. Now, I’m going out on a limb here and I’m saying I just have a 433mhz case with 315 guts. Within that I have a non functioning or static functioning ignition key. Correct me if I’m wrong, I would at the very least need a functioning key in order to program a new key, at least in the traditional way? 08 l322 4.4 HSE Black/Jet. |
16th Jan 2023 2:03pm |
That's correct & why I wouldn't muck about with the oriiginal. I think you may have to bite the bullet & get another wide blade fob on 315mhz |
16th Jan 2023 3:01pm |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 144 |
I recommend ordering a 315MHz key from the Land of the Rising Sun.
16th Jan 2023 3:32pm |
