![]() | Home > Technical (L322) > P0172 - System too rich (bank 1) |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
I've had similar in the past on my BMW where I've found an air leak in the inlet tract pipework/vacuum system causing odd running, and also leaky injectors can cause similar codes
An intake air leak can cause this DTC - more likely to be O2 sensor though, not the actual value, just the rate of change can be slow. Diagnostically, I've cleaned them with carburettor cleaner and reduced pressure compressed air (~50psi), this has worked but we'd always change the sensor, mainly because JLR wouldn't pay for cleaning as a diagnostic but would pay the replacement time. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3179 ![]() ![]() ![]() |
Was that causing rich running?
It'll run lean until it 'realises' it's running lean, then (over)compensates - which sets the DTC. |
Cheers Phoenix.
I can't see a problem with doing that!
Good point about the plugs, I might take them out just for a look. It really is silky smooth at all times though so I doubt it’s an injector.
It'd be worth swapping them over to prove it's nothing else and save unnecessary expense. If the fault does move with the sensor, given the age (and presuming they're originals) it'd be good preventative maintenance to replace both. There's no teach-in process, they're just fit & forget. |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 606 ![]() ![]() ![]() |
David
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic55398.html
Few more observations today:
After another 15 or so miles in a 30 limit the engine management light came bank on with the same code for Bank 1 being rich. These were the fuel trims with the engine idling again:
If I check them with the ignition on but the engine off I get the same readings as in my original post. After seeing how close they are now with the engine running I’m inclined to lean more towards something common to both banks. I’ve got all 4 oxygen sensors and a MAF in my basket for Island 4x4 as I’m sure they’re all original at 138k so it won’t do any harm to swap them all out. Am hoping to get time to take the engine cover off it tomorrow and give everything a once over or maybe even try a smoke test to see if anything is visible. David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
Think am going blind 😂 thought you were saying too lean.
All 8 of them are virtually identical.
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 ![]() ![]() ![]() |
I agree, as the fuel trim is taking out fuel to both banks I would start with looking at things common to both banks, and initially at least, discount an issue on a single injector or a single O2 sensor (and what's the chances of two or more going bad at the same time in the same way?!). You need to look at short and long term trims whilst driving as at idle will only tell you part of the story. If when driving the fuel trims are closer to 0 that would indicate the problem is only at idle and may help you with what to do next. Have you checked the fuel pressure incase there is an over pressure issue? |
