Home > Technical (L322) > torque converter
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
torque converter
hi all looks like my tc is playing up so going to have to replace it .... mines is a 58 plate 3.6 6speed box can i put in a tc from a 2010 3.6 8speed or will it have to be from a 6speed box thanks
Post #653366 12th Jan 2023 3:01pm
garyRR
Pretty sure it needs to be from the 6 speed, however there's plenty of refurb units available inexpensively on ebay. Also, I'm pretty sure the 3.6 never had an 8 speed box, so think there's a mis-print anyway. 2015 Range Rover Autobiography 4.4 SDV8
Post #653376 12th Jan 2023 5:59pm
will308f
yea i was thinking the same thing just wanted a bit of confirmation before i went back to the person selling the tc and questioned them .... Thumbs Up
Post #653398 12th Jan 2023 8:16pm
garyRR
The 6 speed has a gear level. The 8 speed has no gear lever and an electronic rotary dial. Easy way to confirm. 2015 Range Rover Autobiography 4.4 SDV8
Post #653399 12th Jan 2023 8:27pm
will308f
just had a replay back and it has the gear lever same as mine Smile magic
Post #653401 12th Jan 2023 9:16pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Changed the torque converter last month on my 2008 3.6 (6 speed box) before it gave up all together and killed the box, got a recon one from BMWE39MAN on ebay. After speaking to Doug on the phone (his number is on the listing) there is only one torque converter for the 3.6 and he recommended changing the box input seal which he has on the shelf at the same time, did the valve block bridge seals while we were in there plus oil and filter of course and now no shudder and box changes gear fine.
Post #653411 13th Jan 2023 12:58am
will308f
@ kids2 thats great news i will defo be in contact with him ,i did have in mind to replace the valve seals + bridging adapter but didnt know about the pump seal but change that as well .......is the pump seal the one on the shaft going in the gearbox itself (inside the bell housing ) ?
Post #653415 13th Jan 2023 5:18am
kds2
Yes sir thats the one Doug has them on the shelf cost of £10 end of last year when I did mine. As for the bridge seals think I found a link on here for them (memory not what it was it`s an age thing lol )
Post #653437 13th Jan 2023 1:18pm
