Home > Group Buys > L405 Jack Pad
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
L405 Jack Pad
Hello
While working on my RR I needed to jack it up. I looked for jacking pads but found none for the L405. I saw both rubber ones and ones in Aluminium.
So I have done some CAD to design one. A friend is 3D printing one for me to test fit.
I have started to get quote to get one CNCed in Aluminium. Later on, a second one could be created to go on top of a bottle jack.
My question is are people interested in doing a group buy as that will bring down the cost? €20+p&p
I will post photos next week. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #652480 4th Jan 2023 8:35am
luxmoggy
Here is the 3D printed version. I can start asking for quotes for Aluminium CNC one.
It fits the jacking point with very little play.
So the more that are ordered the cheaper they are. Is there anyone interested? SDV8 AB MY 2020
Post #653277 11th Jan 2023 10:31am
What problem does this fix ?
Is it for a trolley jack ?
I've not experienced any issues with just jacking mine up using a trolley jack, though mine does have deployable steps, so the jacking point is lower.
Post #653279 11th Jan 2023 11:39am
luxmoggy
Not fix an issue as such. Like all jacking pads, it protects the jacking point from the top of the trolley jack and provides a better contact area. There have been a few threads asking about L405 jacking adapters/pads. So I assumed others like me could be interested.
I am also looking at bottle jacks for the car and I would try to create another version which can be fixed/attached to the top. Once I find a bottle jack I like and the size that works.
On the jacking point:
It also fits on the normal jacking point. SDV8 AB MY 2020
Post #653290 11th Jan 2023 2:18pm
Gremlin500
@Luxmoggy:
I’d be interested in a couple of these, but I’d prefer to see that central cross-piece removed, and two triangular butresses outside of the central groove.
As is, the jacking point sits atop the cross-piece, so all the force is on one point, instead of being supported along the full length of the groove.
Hope you don’t mind me, just my constructive thoughts…….. Mr. Green “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #653297 11th Jan 2023 3:41pm
luxmoggy
The central cross piece is for location only. It is short enough so that it doesn’t do supporting.
For the outer walls they are the same as lots of other designs - if fact I made them thicker. But I will about the extra support. SDV8 AB MY 2020
Post #653299 11th Jan 2023 4:15pm
Hmm, something I hadn't realised I needed, so I'll have one Laughing
I'm more interested in a bottle jack though as I've not found one yet, although I haven't looked that hard....
Post #653527 14th Jan 2023 7:50am
nbunney
Would the sprinter jack not do the job?
They are a common jack used on the L322
Post #653543 14th Jan 2023 10:54am
Sprinter jack is too tall - at least it is if you have deployable steps fitted, Im not sure about without.
With deployables, the jacking point is part of the step and lower down, so you'd need quite a short bottle jack, but with a high lift, which is a lot to ask.
Post #653571 14th Jan 2023 3:49pm
would it not work if you were in off road mode? ... - .- -.
Post #653576 14th Jan 2023 4:34pm
I think I tried, but can't remember. It's fairly low in standard mode though -
I can't recall how much extra height off road mode provides.
It would need to be at least a 3 section jack to get high enough
Post #653577 14th Jan 2023 4:41pm
Gremlin500
@Luxmoggy:
My bad about the cross-piece very sorry, I’ve just seen Alistairs pic and had completely forgotten about the notch in the vehicle jacking point, which it no doubt fits neatly into, so no issue at all Embarassed Very Happy Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #653581 14th Jan 2023 5:47pm
minim
Norway 2013 Range Rover TDV6 Santorini Black
Did You get these cnc machined? I got a cnc mill so I could look into it. I want them for myself so I will make a set for my own use at least. But is it a good idea with aluminum? Won’t it damage the paint on the jack pads so it can start corroding?
Post #688161 15th Mar 2024 4:42pm
zenman63
England 2016 Range Rover Autobiography SDV8 Indus Silver
Any progress on this?
Had a front tyre blow after hitting flying brick on the road and I am now looking for Jack solutions with a flat tyre.
Post #694450 14th Jun 2024 6:15pm
minim
I kinda forgot about making a set for myself but I’ll see if I can get it done this week. I’m located in Norway tho and not really interested in making these for profit but I’ll help out if I can and they are quick to make. I would have to design my own if the drawings are not published.
Post #694451 14th Jun 2024 6:18pm
