Home > Maintenance & Mods (L322) > TPMS canceling with GAP tool G3
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
Hi all
I have this annoying warning msg on startup saying my tires are set for low load.
I don't have TPMS sensors on my wheels.
Anyone knows how to cancel that definitively with a IIDTool ?
Sylvain "it needs some intelligence to undestand you may not have enough"
Post #652959 8th Jan 2023 12:46pm
Phoenix
I don't use Gap IID but I imagine it'd be the same as any other capable tool, edit the CCF and ensure it's copied to the master & backup (in the car, not on your device).
Post #652976 8th Jan 2023 2:17pm
ergobyte
Yep that's what I feared, editing the CCF.
I was hoping someone had done it already with tha GAP tool so I'd get more precise guidance. "it needs some intelligence to undestand you may not have enough"
Post #652988 8th Jan 2023 3:25pm
JayGee
The GAP IID tool copies the cars CCF file to itself when you first connect and pair it to the vehicle. 2012 TDV8 Vogue (L322)
Post #652989 8th Jan 2023 3:28pm
Phoenix
Your situation seems unusual to me, did you ever have TPMS? it seems odd thinking about it that you're getting the 'low load' message when you should be getting a TPMS error with the warning light illuminated.
If you don't have and never had TPMS, then there is a data mismatch somewhere.
Post #652995 8th Jan 2023 4:05pm
ergobyte
I'll take a picture of the warning and "I'LL BE BACK" ! "it needs some intelligence to undestand you may not have enough"
Post #653140 10th Jan 2023 9:12am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
in cluster menu should be setting for load. change it.
Post #653162 10th Jan 2023 12:30pm
