Home > Technical (L405) > Another Battery Thread!!
Rrsport2020
Ive read a lot of posts about batteries and the symptoms of them failing but I've read conflicting solutions so I want to ask a simple question and hopefully get a simple answer
My car gives me the low battery / start engine message and the tailgate doesnt always raise fully and also the lower tailgate doesnt fully close all of the time, it needs a push.
From what I have read this combined with the battery message indicates a low and failing battery.
So I am finally getting to my simple question Razz :
What battery should be replaced? The main battery or the auxiliary battery?
thank you. Bow down
Post #653083 9th Jan 2023 4:52pm
have them both tested and go from there , but i suspect its the big one in the boot. ... - .- -.
Post #653084 9th Jan 2023 5:17pm
Gremlin500
#2,
If I dare to repeat it again: "The tailgate is the Barometer for battery SOC on the L405"
There, I've said it! Mr. Green “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #653092 9th Jan 2023 6:11pm
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Ha ha, wish I had read that a while ago. You're right!
I fixed my "tailgate problem" with a CTEK battery conditioner.
Post #653097 9th Jan 2023 6:29pm
Gremlin500
Hi RRV8SC:
You may find like me it’s not a permanent solution.
Better to change the battery sometime before you need to leave the car at an airport for 2 weeks………
- or at least before next Winter. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #653652 15th Jan 2023 6:33pm
Vogue
If the battery is knackered it’s knackered - no reconditioner can fix a worn out battery - they are cheap just fit a new one and have done with it before it really lets you down in a most inconvenient location and at a really awkward time when you really need the vehicle 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #653680 15th Jan 2023 9:59pm
Rrsport2020
Thanks all,
How do we know which battery to order?
Might just replace both batteries if anyone has any recommendations.
Thanks
Post #653921 18th Jan 2023 6:06pm
cass
I just order both from Tayna based on the reg number, next day delivery and you're sorted
Post #653926 18th Jan 2023 6:19pm
Kot
My 2018 also had low battery issues when I bought it. I bought a CTEK and 2 years later and the battery, it's still going good. Like all FF they are power users and I usually need to do a charge every 2-3 months. The dashcam also takes its toll Whistle
I must remember to reduce the sensitivity Rolling with laughter even a rain shower activates it. 2018 SE SDV8 4.4 Byron Blue
Post #653934 18th Jan 2023 7:10pm
