Home > Maintenance & Mods (L322) > Steering coloum adjuster lubricant advice
Reformed
When my steering wheel goes back in it squeeks a bit. (only going in, it does not make any noise going up and down or out) I have tried a couple of lubricants including WD40 and silicon lubricant but within a day, the squeek comes back, any one know what is best to use?
I am considering applying grease to the thread but I didnt fancy applying that if that could damage anything. Reformed
Post #65308 22nd May 2011 8:32pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
i greased mine about 8 months ago, been fine... Thumbs Up 2004 black Vogue TD6
Post #65314 22nd May 2011 9:15pm
Reformed
Thank you, grease it will be then! Thumbs Up Reformed
Post #65317 22nd May 2011 9:30pm
dan_uk_1984
You definitely shouldn't use WD40 as it acts as a solvent rather than a lubricant. It strips grease/oil off of things (that's why you use it to clean greasy tools) which then means things will wear much faster.
There is a special thin grease LR use, I don't have the part number to hand, but it is available as a separate part to the steering column and comes in a little sachet - perhaps someone with Microcat could give you the part number Thumbs Up
Post #65388 23rd May 2011 1:42pm
