Home > Technical (L405) > Airbag warning light? |
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 |
This fault seems to plague a lot of 405s.
20th Sep 2021 10:44am |
abs66 Member Since: 26 Apr 2016 Location: Warrington Posts: 93 |
I'm currently looking for a fix for this.
6th Jan 2023 5:57pm |
Historian Member Since: 16 Mar 2019 Location: Lancashire Posts: 32 |
Mine's done this twice over the last four years of my ownership (the first time when I'd only had it a week). I was told that most commonly it's the connector under the driver's seat, which slightly loosens. A quick fiddle under the seat pressing the two sides of the connector together again seemed to work. I switched off the automatic seat backwards movement upon ignition off which did the job until last week when it happened again. Once more a fiddle with the loom worked. Clearly a common problem which JLR should have sorted out. Looking back through my paperwork, the first two owners of my vehicle had the loom replaced twice under warranty, firstly in 2014 and again in late 2015. |
6th Jan 2023 9:22pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
SRS connections have gold plated pins, the problem is they are susceptible to contact fretting having a relatively soft contact surface, this is exacerbated by having the harness unrestrained within a short distance of the connector housing.
6th Jan 2023 10:40pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
See this thread for images of the underside of the seat...
6th Jan 2023 10:55pm |
Yep, that C33 B1/B2 looks like there should be another 10mm or so of wiring and some sort of strain relief, TBH, most connectors are only there for the convenience of the assembly line, if it were mine, I'd snip it out and solder a bit of wire in it's place. and run a stiffener across the joints to prevent any stress on the solder. |
6th Jan 2023 11:08pm |
Apologies for late reply,
24th Jan 2023 11:26am |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 333 |
We took two dogs to the vet tonight. I removed the parcel shelf and put it on the back seat. When we set off I noticed the airbag light stayed on 🤬
27th Feb 2024 8:28pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1410 |
When my airbag light came on, following advice from fellow members, check wiring under passenger seat, don't unplug anything but check all connectors are pushed home. |
27th Feb 2024 8:46pm |
Thanks
29th Feb 2024 3:33pm |
Mine appears to be under the drivers seat. I adjusted the seat today and the light went out! |
2nd Mar 2024 2:02pm |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 156 |
Had mine come on a couple of times and moving the seat around chases it away for a while. Maybe a permanent fix is to loosen the seat, tilt it back and get to the connectors to do a proper job. Probably wise to disconnect the battery first to avoid an unwelcome airbag appearance. |
6th Mar 2024 7:30pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
I’m unsure why they all fail in a similar fashion… Not like it’s vital now is it… 🙄😜 |
6th Mar 2024 9:43pm |
Poor design. This happens so much with all manufacturers and we’re left to pay for it. |
7th Mar 2024 7:32am |
