Home > Technical (L322) > Bodsy remap. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3235 |
On the 3.6 an EGR delete is a sensible thing to do given their propensity to fail and damage turbo's and engines. 2012 TDV8 Vogue (L322) |
6th Jan 2023 2:05pm |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 |
My 2010 3.6 had a remap and egr’s blanked and mapped out at that time car had 47500 miles it’s now on 105000 and it’s still running ace |
6th Jan 2023 7:46pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Do it and never have to worry about the risk of the EGRs being ingested into the turbos. If I had a 3.6 I’d do it on day 1 of ownership.
6th Jan 2023 9:29pm |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 420 |
Thanks. Did you get your’s mapped as well? 2009 pre-facelift 3.6 TDV8. |
6th Jan 2023 10:34pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
We have mapped more than a hundred 3.6's and never have we experienced any reliability issues... That said! All our maps are tailor-made to the particular vehicle rather than a generic off-the-shelf map for a 3.6 or 4.4... So... I'd say "go for it" you will wonder why you didn't do it years ago... |
7th Jan 2023 12:07am |
Good to know. The email did mention that the map would be car specific which is good. Out of interest is the difference all about software versions or are all 3.6’s somehow slightly different so that they need individual tailoring based on current condition and parameters that are read before remapping?
7th Jan 2023 12:59am |
You get a Monday engine and you get a Saturday overtime engine! Also milage, servicing and how the engine has been used all its life… That’s why the MAP needs to be tailor made sir… |
7th Jan 2023 1:10am |
Pimpinthepidge Member Since: 17 May 2021 Location: Glossop Posts: 9 |
That’s crazy…how do you know the difference? Is it readings and pressures? When I first started my working life, I was at Nissan and the mechanic there had a brand new Almera and used to floor it everywhere he drove, saying it would “open the engine up to make it quicker” lol |
7th Jan 2023 9:34am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2485 |
Do you mean that each vehicle is dyno'd and exhaust gas analysed or that the ECM is read then the new maps provided for that ECM? |
7th Jan 2023 10:30am |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 |
The last vehicle I had re-mapped was a VW T5. It had a hybrid turbo & large bore exhaust to help. It was done on a dtno (rolling road) with all factors taken into account. It produce 200bhp & the torque increase was awesome (I don't remember the figure). It was a very, very quick van, too fast for a van if you were in-experienced.
7th Jan 2023 1:49pm |
'Mega-flush' pumps new fluid around the box via the cooler hoses to replace all the old fluid with new. It may or may not include a pan ( filter) change and the machines that do this are not all the same or equaly as good so best to use a trusted outfit like 'Brodsy'
7th Jan 2023 2:07pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Personally, I would never remap a vehicle with more than 18-20k miles on it, the reason being that all the initial wear ('bedding in') will have been done with the OEM limits, suddenly increasing the available torque on a settled engine and drivetrain could accelerate ageing and increase the wear rates.
7th Jan 2023 2:17pm |
Depends much more on how it's driven and cared for IME. A car in stock form driven aggressively on a daily basis and infrequently serviced will wear much more quickly than a sensibly remapped car driven occasionally hard and frequently serviced. Many OE manufacturers offer approved remapping services (eg Polestar for Volvo) which don't invalidate warranty so they must be not considered as life shortening. I've remapped cars but unless you are also upgrading hardware at the same time like exhausts, turbo's injectors there are limits to what is possible on stock hardware before safety systems and limiters kick in and stop the fun so most remaps are just nudging the power limits up to where the manufacturers set safe limits anyway. On a 3.6 I'd be wanting something that eased in the power to prevent shock torque loading on the gearbox and TC which ironically can be caused by faulty EGR valves so mapping these out is likley enough on it's own 2012 TDV8 Vogue (L322) |
7th Jan 2023 2:43pm |
What I got on email from Bodsy about his map:
7th Jan 2023 3:03pm |
