Home > Maintenance & Mods (L405) > Troll Jack Recommendations
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Hello
While doing my oil change on old (20 years) 2.5-ton trolley jack wasn't up to the task.
What trolley jacks do people recommend for working on the L405?
Tons? Lifting height?
Many Thanks
Iain SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #652482 4th Jan 2023 8:44am
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I have a 2.5 ton low profile floor jack with a lifting height of 20”. I also have four composite 7” ramps rated at 6.5 ton each that I use when going under. With the wheels on and in the high suspension setting, it is comfy and safe under there. Always use a jack stand wheel taking off a wheel. YRMV.
 Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #652506 4th Jan 2023 3:24pm
I have the Clarke 3T rated high lift one everyone seems to go for.
For oil changes I use sleepers cut into 3ft length with a slope to drive onto them rather than jack up. The end result is like the photo above except I made them with my chainsaw and I trust wood more than a composite plastic if I am under a 3T car. Discovery 4 HSE
Post #652507 4th Jan 2023 3:33pm
Re: Troll Jack Recommendations
You do know you can vacuum the old oil out without grovelling on the floor... Thumbs Up Pete
Post #652509 4th Jan 2023 4:04pm
luxmoggy
I know that. I was trying to level out the front of the car. SDV8 AB MY 2020
Post #652516 4th Jan 2023 4:51pm
Kot
I have SGS Engineering 3 Tonne Heavy Duty Trolley Jack with 465mm Lifting Height ideal for what I need. Think it cost about £60
And SGS Folding Steel Wheel Chocks With Rubber Feet 2018 SE SDV8 4.4 Byron Blue
Post #652521 4th Jan 2023 5:06pm
pld118
Bought a Sealey 3040AG 3 tonne rocket lift trolley jack last Spring… got it for £148 incl delivery via an eBay 10% special offer… brilliant piece of kit.
https://www.sealey.co.uk/product/563717329...9KHvjGhzHE
Post #652523 4th Jan 2023 5:25pm
ttrw2
Halfords Pro 3T with low saddle and 500mm lift - 3yrs warranty and £120 on trade:
https://www.halfords.com/tools/garage-work...63118.html
Post #652536 4th Jan 2023 7:10pm
luxmoggy
Thanks for the replies. So it just seems my old jack is dead. I will see what 2.5/3T one I can find locally.
My old stands I lent to a friend, who needed to keep them in the end, so gave me a good bottle of whisky for them. I will need a new set. What height axle stands are needed to change wheels? SDV8 AB MY 2020
Post #653101 9th Jan 2023 6:49pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Have a look at SGS they do a good range of solid gear
https://www.sgs-engineering.com/?gclid=EAI...gKaWfD_BwE
I’ve got their axle stands 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #653118 9th Jan 2023 8:52pm
