Home > Maintenance & Mods (L405) > oil cooler replacement how to? |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 351 |
Mine has been emitting fumes for a while but has progressed to dripping oil on the drive so I'm going to have to sort it.
16th Dec 2022 7:54am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1368 |
Which oil cooler ? V8 or else ... |
16th Dec 2022 10:00am |
The one in the V on the engine Current
16th Dec 2022 12:30pm |
Decided to take the plunge and do it myself and save a fortune....or so I thought.
28th Dec 2022 11:29am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8239 |
A normal day in the life of a RR owner.....
28th Dec 2022 12:35pm |
And post a picture and the part number of the part in the cooling system that failed..... Pete
28th Dec 2022 11:33pm |
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 350 |
Fair play to all those doing this job themselves. Had mine replaced early last year. From memory wasn't hugely expensive at the independent I use, although I did provide the parts. |
30th Dec 2022 11:28am |
The part number on the pic is all I required or actually more than I required, it comes with the rubber pipe, I just needed the elbow. I've ended up with everything in that diagram.
3rd Jan 2023 8:08am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
Mine broke too but i could not locate a part number and needed the car back on the road. so i doctored a fix.
3rd Jan 2023 1:22pm |
What retains it? the original has a plastic clip that locks it the thermostat housing. Current
3rd Jan 2023 7:56pm |
Andy,
4th Jan 2023 8:52am |
This is the pipe i changed
4th Jan 2023 8:56am |
Same pipe just opposite end, god knows why they've paid someone to come up with this invention when barbed fittings and jubilee clips have done the same job for the last century+
4th Jan 2023 2:54pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 295 |
I now have the exact same problem oil cooler been replaced at garage they noticed a slight weep from the thermostat housing water outlet part number LR110459 managed to get this eventually but then the elbow broke off the water outlet connection part number LR036058 and we cannot get this anywhere on back order apparently this is for the whole assembly and I only need the elbow.Cheers for the part number for the hose with elbow only but can't get this anywhere so other alternative is to buy another make vehicle similar hose with the same end elbow connectors we have found the same end elbow connector on a Range Rover 5.0 V8 bleed hose see image
18th Jan 2023 9:28pm |
