Home > Technical (L322) > New purchase 4.4tdv8 360 camera issue |
Nyorks2022 Member Since: 04 Sep 2022 Location: North yorkshire Posts: 33 |
Pic didn’t attach |
1st Jan 2023 5:18pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8311 |
Had the surround cameras on the last three fattys and TBH they are just about useless in day to day driving, you play with them to start, show your mates how they work and then never look at them again, so you can save some money and just leave it....
1st Jan 2023 7:04pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Because of the size & type of connector, they're a pain to test without the breakout box, and even then, you can only really check the correct voltages are getting to the plug that goes into the camera - it was much quicker to keep a damaged one (which happens quite often) and plug that in, if it worked, then it needed a new camera, which was the case 98% of the time.
1st Jan 2023 8:04pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2518 |
You could try reseating the connectors in the control module which is under the front passenger seat. |
2nd Jan 2023 3:04am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
+1 for GraemeS' tip - connectors can work loose
2nd Jan 2023 7:21am |
