Home > Technical (L405) > Weak battery and terrain response |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
You can try disconnecting the battery, give it a full charge then reinstall it, that is the only reset you can do without using a diagnostic tool which is your next action if the disconnect doesn't work... Pete
28th Dec 2022 11:39pm |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 383 |
Got it! Thanks Pete |
28th Dec 2022 11:50pm |
I tried disconnecting the battery, then charging it, then hooking it back up but it did not change the unresponsive "terrain response" knob. |
11th Jan 2023 12:11am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
I had the same issue with the rotary gear knob - total lockout - it was the battery goosed - bought a new Halfords battery and issue immediately solved 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
11th Jan 2023 9:06pm |
