![]() | Home > Maintenance & Mods (L322) > Persistent injector driver circuit performance bank B |
peternicholls Member Since: 12 Mar 2022 Location: Stoke-on-Trent Posts: 36 ![]() ![]() ![]() |
I found the two power in pins. Checking tomorrow |
Two? there should be three supplied by the 25A fuse, Connector 'A' L1, L2 & L3 with four grounds on the same plug, pins M1, M2, M3 & M4 there is also a unswitched +ve on pin K4 |
Well, I’m sure you can appreciate the wiring diagram takes quite some time to go through to match ECM pins to it |
It's all on one sheet for the power and ground connections.
All those grounds are sound. If the fuse was out it would show both banks, or more, or no Ecu. All fuses are fine in the engine junction box I will double check everything thurs |
I'm not saying the fuse may be blown, there may be volt drop across it or corrosion at the soldered joint ('SJ' on the diagram) so it's vital to check for correct voltage at the connector under load If necessary, use a dummy load (55w Halogen is ideal) which will provide enough current draw to highlight any low voltage issues. |
SOLVED
Well done - I think the bank A & B refers to the internal MosFET layout, it could refer to the connectors though.
I thought I had too!!!! |
