![]() | Home > Maintenance & Mods (L322) > Rear boot seal LR024161 - How to install? |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 883 ![]() ![]() ![]() |
I believe there’s a mastic type substance already applied to the inside of the seal - it does just push on, only tip I’d give to make sure the ends meet up correctly is take care around the corners to ensure it’s pushed right on |
rscsmith Member Since: 07 Aug 2022 Location: Sussex Posts: 27 ![]() ![]() |
Thanks JCW. '07 Range Rover Vogue SE TDV8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35475 ![]() ![]() |
many threads on this , heres one ,
Apologies and thanks Stan. I did lots of searches about water ingress, then didn't do one about installing the seal! My bad. '07 Range Rover Vogue SE TDV8 |
