Home > Technical (L322) > FBH
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
FBH
Hi guys,
No power to the fuel pump! Which fuse in the boot??
Merry Christmas
Chefski 2014 vogue se
Post #651308 20th Dec 2022 9:52pm
Merchy
Found this list of fuses / relays for 2002 to 2012 models hope this helps.
https://www.google.com/url?esrc=s&q=&a...mWRlAI-qZL
Post #651388 21st Dec 2022 5:48pm
Merchy
Just dug out my handbook for my 2006 Td6, in the book it has fuse No 59 (20 amps ) situated in the passenger compartment fuse box, named as 'Auxiliary heater ( diesel models only) independent heater' and in the rear load space fuse box it quotes fuse No15 (25 amps ) simply quoted as for 'Fuel pump'
Post #651391 21st Dec 2022 6:05pm
Phoenix
The Webasto fuel pump is supplied directly from the FBH so there is no separate fuse. If the fuel pump is not operating, check there is a pulsed output from the FBH, if OK, then you need to access the pump to check the wiring there. Sometimes the pump can sieze due to lack of movement, a good few taps on it can free it off, once you've got to it.
Post #651402 21st Dec 2022 7:04pm
