Home > Technical (L322) > Rear window rolling down by itself - Fixed! |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 586 |
My rear right window doesn't want to stay shut and keeps rolling down by itself.
19th Dec 2022 5:08pm |
Update:
20th Dec 2022 7:53am |
Regarding the failed switch, I tend to believe it's the terminals inside it that have made contact with ground due to corrosion.
20th Dec 2022 8:44am |
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 104 |
fingers crossed you've cured it obviously until the next thing |
20th Dec 2022 8:57am |
Oh the joys of JLR products ownership |
20th Dec 2022 9:01am |
MarkMurphy Member Since: 30 Oct 2022 Location: Cambridgeshire Posts: 16 |
I would also look at the anti trap wires. |
20th Dec 2022 9:30am |
I thought about the anti trap strips but the clicking only occurs when the child safe is disabled. Windows roll up and down normally after the switch replacement. |
20th Dec 2022 9:36am |
So, my rear left window switch finally also failed for good.
21st Dec 2022 5:02pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
Excellent job. Saved some money there and you know your fix should be good.
21st Dec 2022 5:23pm |
Thanks, yes it actually took me two attempts to get the cleaning just right. It takes some persistence with the eraser at the bottom part of the contacts board. But if I can do this, anyone can Definitely worth a try. New part comes at €150 (goes together with the plastic trim). I'd rather spend that kind of money elsewhere... |
21st Dec 2022 5:35pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 276 |
Good job, thanks for the write up ! TDV8 4.4 2012 |
21st Dec 2022 8:48pm |
glad your sorted mate, nice to see these things are repairable given a bit of thought and time rather than just throwing money at issues |
22nd Dec 2022 4:56pm |
