Home > Technical (L405) > 4.4 SDV8 EGT Sensor location
rstoughy
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Hi,
New member just looking for a little info.
Bought my L405 AB back in June this year. Done just over 10k miles since and love it.
The car has developed an issue which has been diagnosed as EGT Sensor - Bank 1 Sensor 2.
Now looking at the exhaust there seems to be a helluva lot of sensors on there.
Anyone shead any light which one it actually is please?
I did the usual searches but none seemed to answer this actual question.
Thanks,
Paul.
Post #651134 19th Dec 2022 2:52pm
fisha
Edit …
EGT or EGR ? And did you get an actual code like PXxxx ?
Sensors aren’t always obvious as to where they should be and the code helps locate it. V8 or else ...
Post #651138 19th Dec 2022 3:32pm
knwatkins
Bank 1, sensor 2 EGT (exhaust gas temperature) is the temperature sensor post-catalyst but pre-DPF.
This one...
 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #651139 19th Dec 2022 3:38pm
rstoughy
Hi Fisha,
Yes EGT and the code reads as follows: P2031-00 / Exhaust Gas temperature sensor - Bank 1 Sensor 2
Post #651140 19th Dec 2022 3:41pm
rstoughy
Thumbs Up Thumbs Up
Brilliant thanks knwatkins
Cheers,
Paul.
Post #651141 19th Dec 2022 3:44pm
knwatkins
No problem Paul. Part number is LR022906 by the way. Cost about £60 online. Kev
Post #651142 19th Dec 2022 3:49pm
rstoughy
Brilliant thanks appreciate that Thumbs Up
Cheers,
Paul.
Post #651143 19th Dec 2022 3:53pm
roel2018
Belgium 2017 Range Rover Autobiography SDV8 Carpathian Grey
Hi... my local Land Rover dealer asked 3 hours to replace this part L022906. I think that is too much. Is it easy to reach this part to replace and wehen DIY, how many time?
Thanks! 2017 Range Rover 4.4 SDV8 Autobiography DPF - 100k miles - Dutch
Post #660839 1st Apr 2023 10:22am
rstoughy
Hi,
It is easy to reach however there is a strong possibility that it will be seized in the exhaust and will require heat or drilling to remove (should it shear off)
I think 3hrs is ok time wise allowing for that.
Thanks,
Paul.
Post #661417 9th Apr 2023 10:18am
add84
United Kingdom 2016 Range Rover SVAutobiography SDV8 Mariana Black
hi can someone help please I have a l405
4.4 diesel I have the code p0546-17 bank 1
sensor 1 if I stand at the front of the car is it
no the left or right side. thanks adam.
Post #698669 23rd Aug 2024 11:39am
add84
here's a pic
Post #698670 23rd Aug 2024 11:41am
