Home > Maintenance & Mods (L322) > Suspension down on one side
Page 3 of 3 <123
Valybejan
United Kingdom 2011 Range Rover Vogue 4.4 V8 Fuji White
I did replaced the entire strut,to eliminate the chance of failure Smile. I cannot hear any leak. Is there anyway that the entire air system can be checked? Whilst driving i cannot hear the compressor working,to help the leak....this is very weird...and its only right side.
Post #651026 18th Dec 2022 6:11am
Valybejan
Post #651027 18th Dec 2022 6:12am
kokamagi
Estonia 2011 Range Rover Autobiography TDV8 Santorini Black
Tightening the top of the strut nuts to 140Nm will mostly cure it. Mine did, it holds air now even at -20C.
They leak because some aftermarket kits don't have upper O-rings for some reason. For example Arnott what I used.
You can see the leak, when spraying some soapy water, window cleaner etc in there. It will bubble.
Post #651029 18th Dec 2022 8:42am
Valybejan
I used this one from Island 4x4. I heard only good stories about them.
Post #651030 18th Dec 2022 8:46am
kokamagi
Just check to be sure, easy to do.
Post #651031 18th Dec 2022 8:50am
Valybejan
Will try. Thank you.
Post #651035 18th Dec 2022 8:54am
Page 3 of 3 <123
