Home > Technical (L322) > TD6 - Bong and warning lights
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Evening all
Had the dreaded ‘bong’ when I was driving our 2003 TD6 earlier today, twice about 2 minutes after starting and moving off.
Faults displayed were:
Air Suspension Inactivate
HDC Inactivate
And the following lights on the dash:
ABS Light (yellow)
Brake pad light (yellow - circle with outer parts on each side)
Warning triangle with circle around it and arrow head on circle (yellow)
Also the ride height adjust knob was illuminated in normal height, preventing me from adjusting the height. Tried the usual full lock left then right but to no avail.
She had a new battery fitted 2 months ago, but did sit for 4 weeks recently without use. Only done short journeys since then, 5/6 miles max
Any ideas guys? Weather related I’m guessing/hoping
Post #650790 14th Dec 2022 8:48pm
check battery .. ... - .- -.
Post #650817 15th Dec 2022 11:20am
I'm with Stan, disconnect battery, fully charge it then see what happens... Thumbs Up Pete
Post #650819 15th Dec 2022 12:16pm
mrblonde
Thank you guys
Hayland do I need to disconnect it to charge it? I usually plug it into a trickle charger while at home if its not used for a week or so, would 24 hours trickle charging in situ be the same?
Post #650837 15th Dec 2022 5:27pm
