![]() | Home > Technical (L322) > Weird remote key issue after battery change in vehicle & |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 ![]() ![]() |
Did you replace the batteries with Duracell?. It has been quite well documented that only Duracell work perfectly.
Ian Thompson Member Since: 29 Sep 2021 Location: Dover, Kent Posts: 10 ![]() ![]() ![]() |
Weirdly and by chance yes, the remote battery was replaced with a Duracell 2011 4.4 TDV8 Vogue Santorini Black with black interior and glass
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1268 ![]() ![]() ![]() |
Hi Ian, I bought a two pack of Duracell batteries for mine, and the first battery was only half charged and didn't work, the second one worked fine. Might be worth trying another battery. |
I have 2 spare batteries so I will swap it out for another new one and see 2011 4.4 TDV8 Vogue Santorini Black with black interior and glass
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 337 ![]() ![]() ![]() |
The ones I've had from the stealer recently have all been Varta. 2017 4.4 SDV8 Autobiography in black
Some shots in the dark:
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 146 ![]() ![]() ![]() |
Make sure you wipe both sides of the battery with a cloth or similar, fingerprints are a bit greasy and hinder the flow of current.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1588 ![]() ![]() ![]() |
Worth mentioning, there are a lot of fake batteries out there, especially on the large internet stores.
jordon0 Member Since: 06 Mar 2016 Location: derbys Posts: 53 ![]() ![]() ![]() |
duracell batterys now have a clear film on them that tastes bad to children that may put them in their mouth
