Home > Technical (L405) > IID Tool Draining Battery?
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
If an IID BT is left plugged into the OBD port with the car locked & left for several days, is it likely / accepted this will drain the battery?
Post #650743 14th Dec 2022 3:23pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Yes. 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #650745 14th Dec 2022 3:58pm
I inadvertently left mine plugged in for about a week, it didn't seem to do anything, I know Gap says they can, I suppose it depends...!!! Pete
Post #650772 14th Dec 2022 6:07pm
JCW
I did the same Pete, inadvertently left it in for 3 days and went to drive it today and no response at all from the key fob.
It’s on the ctek now and after an hour or so, it responded to the key and locks / unlock ok - I’ll leave it on overnight.
So in my case (MY15 L405) I’d say leaving it connected does drain the battery - checking the IID manual it does say to always remove after use.
Post #650776 14th Dec 2022 6:19pm
I spoke to Pat about it a while ago, he said they had problems with it sometimes draining batteries so they advise to disconnect, maybe it depends on what you were doing as it may get hung up connected to some ECU and just drain... Hopefully a good charge should sort it out... Thumbs Up Pete
Post #650778 14th Dec 2022 6:23pm
