Home > Technical (L322) > Late (2012 Westminster) L322 LCM Location?? |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 357 |
It is normally behind the trim on the drivers side A post pillar ie next to your legs. If you search fir the three letters LCM there are several posts on the subject including a couple of fixes and a firm that can repair them for circa £80 if at fault. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
9th Dec 2022 9:45am |
GrazzerD Member Since: 09 Dec 2022 Location: Surrey Posts: 3 |
Thanks V8 Bob. I have indeed seached and yes A pilar is where I am at... I have actually just had a callback from LR and he thinks they stopped fitting them to the cars after 2009 but is going to check for me and took my reg. This could explain why I cant find it in this possition. I will keep you all posted. |
9th Dec 2022 10:12am |
So apparently it is hard wired to the door control module and then off to the BCM from there. |
9th Dec 2022 10:15am |
Paul TVR Member Since: 09 Dec 2022 Location: Wiltshire Posts: 3 |
Fancy seeing you here! So you're indicator is wired to the door lock, that's why it doesn't work! |
9th Dec 2022 2:02pm |
