![]() | Home > Technical (L322) > Charging issue? 4.4TDV8 |
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 ![]() ![]() ![]() |
Ok, but what about the cranking time? Is there any proof it also impoves or no impact in that matter? |
A video of what do you mean? |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
record the crank cycle, from the dash and the engine bay SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
Ok, will do later. |
Here's comparison of the cranking test between the old and the new battery.
Has the battery swap fixed your issue? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
10.07VDC at cranking is a little low, various modules will shut down below 10.50VDC
No it didn't fix my FBH problem, at least now i'm certain, that the PCB of the FBH is faulty. |
Battery tester was connected directly to the battery terminals as it should. And literature states, that anything above 9.5V while cranking is considered a healthy battery. Where is the information about modules shutting down below 10.5V taken from? Because I can't find such information in 4.4TDV8 Workshop manual. Have you done a battery cranking test on your car? What did it show? |
9.5VDC at cranking is not a healthy voltage, whatever the documentation that came with your voltage monitor says.
Thank you for the informative answer.
Here's a couple of traces
Yeah, I'm using the car also with all accessories on and only 5-10 min trips so it doesn't get warm even. The ambient temperature here swings between -10 to -20 degrees so after startup, all window defrosters, heated steering wheel, and seat heater get turned to the max.
Yep, I can 'scope it - all the measuring equipment is checked and calibrated every six months and meets the minimum accuracy requirements of the brands my employer works for. It'll have to be next weekend though, weekdays are just too busy for me. |
