Home > Maintenance & Mods (L322) > Second Auxilary Battery |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
If you are going to drive on any tracks / rough ground I would suggest lifting the loom out of the 2nd battery area. It will lift up and nicely go around the rear fusebox. No chance of any rubbing. 2007 TDV8 VSE
8th Dec 2022 10:38am |
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 51 |
hi, thanks for the tip, although battery is on a battery tray, with drain, from a caravan, was careful selecting battery type in particular to it's height. there is a 1" gap to floor, but it is a good idea to move it, will do this, when it warms up outside!! |
8th Dec 2022 5:15pm |
HV_Sparks Member Since: 03 Oct 2022 Location: North Yorkshire Posts: 7 |
Hi,
28th Dec 2022 7:03pm |
