Home > Maintenance & Mods (L322) > L322 Overland build
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
L322 Overland build
HI, All just watched the Overlanding 4WD video the guy is very honest about his problems with the issues he has with his car.
What a shame that he is at this stage after all the preventive maintenance he recommends doing.
Worth a watch you do feel for the guy.
2010BlackL322 is his sign on here.
Post #650120 7th Dec 2022 8:15pm
p38arover
Australia
Link? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #650130 7th Dec 2022 11:32pm
Is it this one?
https://expeditionportal.com/forum/members/2010blackl322.241421/
Post #650134 8th Dec 2022 1:25am
Tinman
This is the one I watched,
Post #650140 8th Dec 2022 10:07am
DrRob
He has a good attitude! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #650191 8th Dec 2022 8:06pm
Tinman
He has just put out another video about a winch on the front.
&t=336s
Post #650467 11th Dec 2022 5:22pm
2010BlackL322
United Kingdom 2010 Range Rover Autobiography Black 4.4 V8 Santorini Black
Re: L322 Overland build
Yep, that’s me :Smile Check out my YouTube channel
https://youtu.be/UHBbLWZXw4A
Post #650915 16th Dec 2022 3:40pm
DrRob
Hope the engine gets sorted soon 🙏 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #650920 16th Dec 2022 4:55pm
2010BlackL322
Thanks,
Hope so too, it’s going back together now, which is a good sign, no more parts are coming off! it also needs rear subframe bushes, both have gone, age, and what I have put it through recently killed those off, and a MOT, as that ran out while it was there in Nov.
Might get it back next week, but chilled about when it comes back.
Much to do when it does come back, sort out my water heater / water pump box, get all that plumbed and plugged in.
18” rims should be next, finally noroadclubd https://noroadclub.com/collections/tuffant-kimberley-alloy-wheels
have a set of 18” rims that do fit over the 6 pot brembos, been confirmed, so no more 20’s off road, although I might just use the 18”s as play wheels and tyres and not every day, the coopers are better on road than BFG KO2’s, will see.
Bash plates are coming in the new year, front plate and engine guard, plus lower control arms bash plates too.
Much to do before the next trip, Strata Florida first, then May, back to Spain. Thumbs Up
More videos coming Thumbs Up Check out my YouTube channel
Post #650922 16th Dec 2022 5:06pm
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Mark,
So glad to see you back on YouTube and the L322 seemingly in fine fettle. Long may both continue to be the case! 🙏
I’m super-interested in your endeavours with the TuffAnt wheels when you get them, due to the ET29 offset; so I think about 29mm further out per corner than the standard L322 alloys and 18mm more than your current L405 wheels. I trialled a set of 20mm spacers on mine with standard ET58 alloys with 265/50R20 tyres. I really liked the planted feel and cornering at speed was certainly improved. However, I got a weird phenomenon that meant I lost front traction really quickly on tight corners in the wet and that caused me to lose confidence on the faster stuff thinking it would let go without warning, so took them off again after a few thousand miles. It seemed to be due to scrub radius being significantly increased by the greater 20mm offset. Anyway yours will be even more so please do let us know how you get on as I’m minded to give my spacers another go over the summer.
Also, it would be really interesting to hear what’s going on with the underbody protection. After your unboxing of the ProSpeed guards and then later explanation about interfering with the DPF, I’m wondering if you’ve modified the ProSpeed guards or had a custom solution fabricated. I’m curious as I’m trying to work out if it’s worth buying ProSpeed to modify, or whether to not bother and start from scratch? Your thoughts are most welcome!
Anyway, please keep it up as your content really is excellent! 👍
Andy Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration!
Post #664441 18th May 2023 6:05pm
2010BlackL322
Andy,
NOROADCLUB confirmed they don’t fit, actually, let me check that, they do, but the owner who did make them fit, shaved MM’s off the calipers to get them to fit. So, they might fit, but not without mods. So, no go.
The bash plates, well, they were loaned to Dirt Monkey, and well, let’s just say, he’s never replied!
The guy I got my rear exhaust box delete pipes from, Ian, has started to fab some, but, the DPF is an issue, so he has suggested to go see him and see what we can do. I just need to get up north, but that won’t happen for a few months.
It’s on the list, but probably a winter project
Hope that helps? Check out my YouTube channel
Post #664448 18th May 2023 8:58pm
