![]() | Home > Technical (L322) > 4.4TDV8 Won't start. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2568 ![]() ![]() ![]() |
Is the engine turning over? |
Assuming the engine is turning over, have you bled the LP fuel side? if so, I'd try cracking off an injector pipe to allow the fuel rail to vent whilst cranking - not too much otherwise it will detect low pressure again. |
Cupidstunt Member Since: 04 Dec 2022 Location: Northern Ireland Posts: 8 ![]() ![]() ![]() |
Thank you both..yes engine turning as usual...I've gone through the bleed procedure as changing the fuel filter. |
Do you have diagnostics that can read live values? if so, what are the LP & HP pressures whilst cranking? |
Thank you Phoenix, l give this a go. Thinking possibly CPS or Fuel pressure regulator? As mentioned it's showing no codes, won't start with Easy Start. Dealer network here in Northern Ireland useless... independents stacked up with work for months... nightmare |
If it won't attempt with easy start (not withstanding it's a long way for it to travel!) then it's more than a fuelling issue, are you sure you got the wiring correct on the pressure sensor repair harness?
Thanks Phoenix, I've an OBD diagnostic...it's showing 0 at the fuel rail before and after the Loom and Sensor change. I know I need to check fuel pressure which Diagnostic tool do I need? |
Hi Phoenix, definitely. Short wire (2) to position (2) of the connector to be removed. |
I've never used Easy start before..the chap from the AA tried..I was less than convinced. |
As mentioned.. absolutely nothing has changed since I did the loom repair, symptoms exactly the same...as fault codes, zero. Only fault codes occurred at the time of breakdown. |
You need something that will read live values, even the most basic OBDII will give fuel pressures, maybe experiment a bit with the one you have? Be aware that most engine management systems won't log DTC's until the engine is running (other than crank/c am position sensor implausibility) so don't rely on fault codes, you need to go back a step to good old manual diagnostics
I suggest monitoring the CPS during attempted starting as a priority because it is so easy to do. |
Thank you all for the help. Finally found "Pressure at Fuel rail" on my IID reader....it showed zero. Removed the HP pump and dropped it into a local Diesel specialist for testing...and it's completely disintegrated and not good news as he suggests that all the metal particles from the pump will have wrecked the injectors so likely not just as simple as a replacement pump... strange as it gave no signs of failure prior to this. |
ASH Member Since: 04 Jul 2018 Location: Staffordshire Posts: 15 ![]() ![]() ![]() |
Sorry to bring up an old thread but I'm having the same issue, 0 at fuel rail.
