Home > Technical (L405) > Noises?
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Noises?
Slight ‘clonk/clank’ sound very occasionally from rear of vehicle on moving off when making right turn on slight incline…..also very slight ‘drone’ at 20 - 25mph on smooth surfaces, none of this at high speed…..any ideas? Can’t re-create the ‘clonk/clank’, just aware of it very occasionally……
Post #649807 4th Dec 2022 11:39am
knwatkins
Is it a judder when moving off and turning?
If so, see technical bulletin 00906, relating to the transfer case double flush and software update...
https://testing-public.carmd.com/Tsb/Download/119041/LTB00906NAS4 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #649808 4th Dec 2022 12:22pm
kgeddes
Thanks for your reply. There is a definite noise when turning right from a standing start coming from the rear of the vehicle best described as a ‘clonk/clank’….it happens very rarely and I cannot re-create it. I’m also aware of a slight droning sound at 20 - 25mph…..
Post #649811 4th Dec 2022 12:55pm
you could have this problem,
https://www.fullfatrr.com/forum/topic37809...=fuel+tank ... - .- -.
Post #649818 4th Dec 2022 2:25pm
kgeddes
Thanks for that Stan. I don’t think it’s that. The sound is more of a ‘clonk/clicking’ sound as against a thumping noise….hard to describe…..more like somethings loose/worn but I’ll try keeping the tank over half full and see what happens, thanks again Thumbs Up
Post #649827 4th Dec 2022 3:33pm
tomo141
I had similar with a clunk from rear on right turn. The double flush and software update fixed it no issues since.
Tomo ------------------------------------------
L460 D350 73 24 model FFRR Autobiography Santorini Black with Shadow Pack
L405 4.4 V8 18 FFRR Autobiography (facelift) Santorini Black with Shadow Pack
L405 3.0 V6 13.5 FFRR Autobiography Santorini Black
L322 4.4 V8 12 FFRR Autobiography Santorini Black (RR Styling Pack)
L322 3.6 V8 10 FFRR Autobiography Santorini Black
L322 3.6 V8 07 FFRR Vogue SE Santorini Black
L322 3.0 I6 55 FFRR Autobiography Santorini Black
Post #649869 4th Dec 2022 10:20pm
kgeddes
Thanks Tomo, were you getting the clunking on a regular basis or very occasionally? Thanks
Post #649896 5th Dec 2022 12:31pm
tomo141
The clunking was just now and then, it could go days without doing then it appeared. It would some times be clunk clunk, very subtle but it was there. Always on a right turn. When it went in to LR, they knew what it was straight away. Since the flush and software update its been fine. ------------------------------------------
Post #649951 5th Dec 2022 11:06pm
kgeddes
Thanks again Tomo, sounds exactly what I’m experiencing Thumbs Up
Post #649955 6th Dec 2022 12:05am
Van Diesel
United Kingdom 2014 Range Rover Vogue SE SDV8 Mariana Black
I wonder if this is what I'm experiencing. Pulling out of a junction and turning left or right, or entering a small tight roundabout from standstill, I can hear and feel resistance from the nearside rear. Feels like a lot of friction/like somethings locked up? Reminds me of the sort of sound you would expect if you had a diff lock in and tried to turn too tight?
Post #654627 24th Jan 2023 9:45pm
knwatkins
Yes, that'll be it. Kev
Post #654640 24th Jan 2023 10:51pm
Gremlin500
Drone could be tyre resonance & unrelated.
Last year we had a metallic, slightly tinny “clonk clank” on ours but only when reversing slowly over a slightly uneven surface with some right-hand lock on. I thought it was heat shields as being the tinniest thing under there, hard to say where it was coming from, sounded like the front end, but weirdly after changing the xfer box oil it disappeared. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #654650 25th Jan 2023 1:23am
