Home > Maintenance & Mods (L405) > Touch Up Side Steps |
Skipper Member Since: 02 Sep 2022 Location: Bangor Posts: 14 |
It’s tempting to use a wire brush for speed and convenience but it can end up introducing rust into freshly exposed metal. Maybe your acid etch will be enough to give you a clean surface to prime and hold off the rust until the spring? |
1st Dec 2022 1:26pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1496 |
I tried to remove mine which looked similar, but despite soaking with Plus Gas many times I simply could not get them off with all bolts out, despite bashing away with a large rubber mallet, so I rubbed them down where the paint had blistered, masked off the trim, and brush painted them with black smooth Hammerite. Not ideal, but they look OK and at least have some protection for now. I guess they’ve corroded themselves to the brackets?
1st Dec 2022 1:39pm |
Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 152 |
Much appreciated, my assumption was corriosion due to a mix of paint errosion on the top edge and maybe stone ships from the edge and beneath. I'll look out the Tank stuff you mentioned.
1st Dec 2022 2:59pm |
