Home > Technical (L322) > Heated cooled seats 2012 full fat
DEEBEE(060)
United States 2012 Range Rover HSE 5.0 V8 Orkney Grey
I have this option but all switches and controls dead. Fuse appears OK. Any other relays on this or is there more than one fuse? I had the car a week and it parted company with high pressure fuel pump as someone had stripped a bolt and not replaced. Pick up next week after engine out and 5 weeks at dealers. Going to get a mortgage for the bill!
Post #634974 18th Jun 2022 9:16pm
Sorry - no idea - but a few threads that may have some info (or maybe not)
https://www.fullfatrr.com/forum/topic44946.html
https://www.fullfatrr.com/forum/topic62958.html
https://www.fullfatrr.com/forum/topic59983.html
https://www.fullfatrr.com/forum/topic51084.html
https://www.fullfatrr.com/forum/topic10106.html
Post #634987 19th Jun 2022 7:44am
DEEBEE(060)
Finally after 8 weeks and $10k got car back but still heated cooled seats completely out. Filters clean but no lights on dash switxhes and test procedure holding button down while turning on ignition gives no lights.
Fuses checked and all seem OK, so I am stumped as can't find a wiring diagram for them. Any help appreciated in advance.
Post #637853 25th Jul 2022 9:48pm
Phoenix
Wiring diagram below - unless you asked the dealer to fix, they wouldn't...
https://www.fullfatrr.com/gallery/albums/u...eating.pdf
Post #637854 25th Jul 2022 9:52pm
DEEBEE(060)
Thanks, now I have something to look for, looks like either wiring or fuse. Maybe a reset needed on gap tool.
Post #637857 25th Jul 2022 10:25pm
DEEBEE(060)
Do I have a missing module?
Post #643763 23rd Sep 2022 11:03pm
DEEBEE(060)
Post #643764 23rd Sep 2022 11:05pm
garyRR
Yes, I can confirm.
Someone has removed the heated/cooled seat module, which is why it's not working. All those spare plugs plug into a box like this underneath the plastic panel below the seat:
It's not the end of the world - I think used ones are around £40/$50 on ebay and last time I enquired with Land Rover main dealer, brand new are around £130/$150. As you've got a 2011-12 RR, I'd personally just go and buy a brand new module, because they can gain electric gremlins over time and the later cars are still worth good money Thumbs Up 2015 Range Rover Autobiography 4.4 SDV8
Post #643766 24th Sep 2022 12:32am
DEEBEE(060)
Module was missing, replaced and still no lights at switches. 3 fuses checked and live. Where next I wonder?
Post #649402 28th Nov 2022 9:20pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Perhaps it needs coding?
Post #649429 29th Nov 2022 8:32am
Phoenix
Nope, it's plug and play.
Are you getting power to the controller (not the module, the dash controller)?
Is the module you've fitted a 'known good' item?
ETA - power & ground connections for the centre facia module
https://www.fullfatrr.com/gallery/albums/u...power2.pdf
https://www.fullfatrr.com/gallery/albums/u...power1.pdf
It's unlikely to be the fuse as it powers the SAS as well, same goes for the ground connection, check both at the centre facia module connector and work your way back.
Post #649567 30th Nov 2022 6:56pm
DEEBEE(060)
After head scratching and while working on parking sensors, I got the GAP tool out and was messing with it for a while. Whilst in there I noticed my heated cooled seats were not installed. Followed the GAP directions and activated them. Now I seem to have heated seats. So missing module and need to activate was my issue. I wonder if they were ever working as the cover plate looked like it had never been removed and was a B to remove
Post #654829 26th Jan 2023 9:10pm
