Home > Technical (L322) > GAP IID Tool Graph
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
GAP IID Tool Graph
Whilst looking at the live values on the tool. If I select the graph, It will go into a loop & then I'm unable to return to the main menu or view the Axis view ( Axis is highlighted in blue, End button highlighted in white). I then have to crash out & reset.
This happens in either Demo mode or connected to the vehicle?.
Post #648624 20th Nov 2022 1:49pm
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Yep, I've had the same. If I recall you have to scroll the page upwards to access the other buttons although I could be thinking of another area of the tool.
Post #649472 29th Nov 2022 6:29pm
Highroller
Yes you're correct, Had an update from GAP & now have both Thumbs Up
Post #649479 29th Nov 2022 7:56pm
